forcefed86
- Jul 28, 2005
I figure a hole is a hole right? If the hole is "X" size it should flow the same as another "X" sized hole?
Reason I ask Is I've been using a 10 micron fuel filter as an inline turbo oil filter. I am still seeing well within spec oil pressures at the turbo. (I have a press gauge pre-turbo)
Recently my PT-68 started blowing oil out the aft seal. I think this was due to excessive head pressure. I rebuilt the turbo and installed the inline filter as stated.
Recently I was told that the fuel filters are alot more restrictive than the oil filters. I'm sure I can get an oil filter that will spin on my setup. But I like where my pressures are now. I'm right around 21ish idle and 60 at rpm.
I'd like to hear your thoughts. Please don't just reply that I should change it without giving a reason.
Thanks all!
Thanks all!
