If it is the original rear, check the option sticker on your trunk lid. The code for posi is G80.
Alternatively, you could jack the rear of the car up (with the front tires blocked, and the car in neutral). If it IS a posi, the tires will rotate in the same direction. If not, the tires will spin in opposite diections.
