John, on average the et=1356/mph and I did check each of the et/mph pairs that I calculated to make sure that they agreed to within 1 mph of that calculation. If the mph had been significantly higher I would have used it to calculate an et and then used that in the hp formula, since as you say mph is a good indicator of hp while et tends to be more an indicator of traction. The hp formula I used is average rwhp = 197 * weight / et^3, which is straightforward to derive assuming constant acceleration (I posted the derivation once in a thread about whether or not the formula was for rw or flywheel hp to prove it was for rw, and the constant acceleration assumption is why it gives average hp). I did round off to the nearest 5 hp. Since you talk about a transmission factor I have to assume that your numbers are estimated flywheel hp numbers, while mine are average rear wheel hp which are going to be lower by whatever transmission loss guess is used. Any formula you want to use is okay so long as you understand what it is giving you, so you can make apple to apple comparisons. In Bill's case I hope his clutch setup is slipping less than the typical converter that makes up part of the transmission loss in your estimate, which will lower your number for him by a good bit. That's why I really prefer the rwhp number, since to me what is important is how much you can get to the track, but that's just me
