No. Though its highly unlikely, someone could swap TA61 guts inside stock compressor and turbine housings and the external markings would be the same.
By looking inside the turbo inlet you can see if the compressor housing has been machined for the larger guts. The opening of a stock turbo housing is smaller than the inner diameter of the inlet bell. Sooooo, if you look inside and this is the case, you have a stock turbo. It's pretty simple actually.
If the opening is larger than the ID of the inlet bell and/or the inlet bell has been machined, the turbo may no be stock, and you'll have to take some measurements.
