You did it all wrong.
First, unscrew and remove the IAC motor (ignition off) and clean the pintle, and also clean the pintle seat and holes in the throttle body. (the conical hole that the IAC pintle seals in). Use carb cleaner and wipe the pintle seat clean with a paper towel. Screw it back in, but dont over-tighten it cause you can crack the sealing gasket for the IAC. (is the gasket in there????)
Warm the engine up. Shut it off.
Turn the idle air screw in a few times to open the throttle blade a little.
Ignition on, short those 2 pins (top right 2 pins) and wait. Shut ignition off. Pull that paper clip AFTER ignition is off.
Pull the IAC connector.
Start the engine. Slowly turn the idle air screw out and keep bringing the idle down until the engine dies.
Turn the ignition OFF.
Plug the IAC CONNECTOR back in.
Now turn ignition on.
Adjust the TPS sensor to .44 volts at idle. Scanmaster makes it easy.
Tighten TPS down.
Shut ignition off.
Start engine.
Good to go.
