Finally got it running tonite, been down since B/G.
took out the motor to replace the short block,bin to the well 1 to many times on a stock short block!!
new short block is girdled with a eagle crank,oliver rods, 20over diamond pistons custom oil pan and crossover pipe.
top end was same as before champion worked tta heads with port matched intake, 212/212 roller cam with harland sharp roller rockers
Goal is to run low ten's on stock computer,TT chip, mass air flow,93 pump gas and Alkycontrol
went 10.8's with the stock bottom end at 23/24 lbs of boost and only 22* of timing
will keep you posted on progress
thanks JD
thanks JD
