J & E .030 pistons/new wiseco .927 pins
johnplogii
Senior citizen
I have a set of used J & E 3.830 pistons with the used pins & used rings. These are for stock stroke/stock rod length. $250 shipped
Set of 6 NEW wiseco .927 pins $50 shipped.
Lots of people PM'd me for pics so I will just post them here. The pins are new .927 x 2.500 x .150 wall, came with new wiseco pistons.
The pins feel a little sloppy to me in the J&E's. I would plan on opening them up & running a slightly larger pin.
Thank you
pistons
Interested in your pistons, about How many miles or on them?
What size pins would i need?
What is the compression height and what is the dish?
1/16 comp rings? What is the pin bore?
Brian, I'm pretty sure the rings are 5/64ths, the pin bore would be a loose .940, they came off of a set of stock rods. I buried these a few months ago in my storage room. If you are real interested I will dig them out. I had two sets of these bought from the same vendor & I know the other ones had 5/64ths rings. Let me know.
Rings for these Pistons are 1/16 - 1/16 - 3/16
Part Number - J100F638305
$112.95 from Summit
could I get the number on the inside of the piston? trying to find out about the pins. you're saying the pins that are in them feel loose to you, correct? i think i'm following now. had read what i wanted to read i guess. it's the actual piston that has the wear and not the pin? i'm interested, obviously. i like j e products. did you actually use these or just had intentions? thanks Clayton
These came out of a good running motor that made no noises. Yes, I am saying that I would want to run a larger pin because they are somewhat loose. If you are really interested I will have to dig them out of my storage room.
