JE Pistons (new)
ESP Products
Banned
I have a set of custom ordered JEs that were never picked up.
The bore is 3.810
Stroke is 3.625
Rod length 6.35
Comp Ratio 8.5:1
These pistons are set up for the above spec.s. If this will work for you, the pistons are available for $400 or best offer.
Hope this helps you.
We are interested in your JE's . Can you provide more info?
Wrist Pin size
Comp Ht or pin ht
Ring widths, 1/16, 1/16, 3/16?
Do you have the speck sheet that comes with the pistons?
Thanks,
Rings size = 1/16,1/16,3/16"
Piston Size = 3.810"
Pin Diameter = .927"
Pin Lengths = 2.950"
Comp Dist. = 1.367
This is all the info I have.
Merry Christmas & Happy New Year!
Thanks,
A good set of pistons, JE is the best!
However, with our deck ht, the 1.367 compression ht won't work.
Good Luck.
