JE Stroker Pistons, locks and rings too **
wickedtt
I have a set of JE Forged Pistons .030 that were installed for a very short time undr 2k miles , this is a good deal for someone $400 plus shipping. Complete with pins, locks and rings..
Tanks for looking
I don't know the pin height off hand all I have written down is the bore: 3.830 used with a stroker 3.625 crank , Rods were 6.350 Pin is .927 . I beleive this is a common stroker piston used in alot of kits.. :)
I don't know the pin height off hand all I have written down is the bore: 3.830 used with a stroker 3.625 crank , Rods were 6.350 Pin is .940 . I beleive this is a common stroker piston used in alot of kits.. :)
If you happen to find the pin height I may be able to use them. I've got a specific project that I need the pin height on. Thanks.:)
It's difficult to believe no one has picked these up! I have a stock bore w/JE's, otherwise I would have taken them.
With that pin height it looks like a 6” connecting rod would work for a deck height of 9.51”. K1 makes a 6” rod but has a .927” wrist pin. Can you check that the .940” figure you quoted before is correct? Also do you know the volume of the dish? Thank you
You are correct sir I measured it today and yes it is .927 on the wrist pin. Thanks
