:biggrin: :biggrin:
I just purchased a motor from someone on the board and it has the following
Here's what I have.
Fully Built 109 with .020 over JE pistons, Pro-gram steel mains 2 center's, stock crank 10/20, stock rods all done, ARP main studs, SPS rod bolts, motor was balanced and is within a few grams on each cyl.
Dale Cherry ported and polished Irons, Bigger valves, Viton seals int and exhaust, de-shrouded around the valves. 100lb comp cams springs, Receiver grooved for 1007 felpro's These heads have not been flowed but were on a 10.0 car before I got them.
Hand ported intake manifold matched to the heads.
Modified front cover with a stock meling oil pump, setup for external oil cooler.
Comp cams 212/212 non-roller cam, degreed in.
F.A.S.T 60lb injectors.
Turbo is a TE-61
Fully built 200r4 built by Otto in CT. Stage Right Transbrake, all the good internals, stock pan, alto red clutches, alto wideband, th200 servo, ect ect. Just gone through and replaced all the seals and cluches. No more than 5k on this. Also has a Vigalante 0 pump 3200 stall single disc too.
I am getting rid of the FAST injectors and buying some 60 siemens
I was thinking of adding Alky injection and maybe changing the turbo
What do you guys think. I would like a streetable 10.70-11.0 car with slicks
Any help appreciated.
__________________
Here's what I have.
Turbo is a TE-61
__________________
