JUNK AC hose assembly
TR Custom Parts
Mark Hueffman - Owner
For an 87, just need the section from the compressor to just past the high pressure fitting a few inches past the compressor. Threads on the fitting the high pressure switch must be in perfect condition. Tightened mine too much and stripped the threads and lost my charge about two years later. Figure I can get that fitting welded on to my otherwise fine hose setup.
This is all I am looking for. The section from the compressor just past the shrader valve. Will have my welder remove my stripped
one and weld another one in
