Well, after having a ride in one about 10 years ago and saying to myself "one day I'll own one of these", I bought the very same TTA from the friend that gave me the ride 10 years ago. It's a cloth/hardtop car, with 2500 original miles. Nearly perfect, I couldn't be happier. That makes 3 of the 15 cloth/hardtop cars accounted for here on this board
The car already runs 12.5s courtesy of a few tweaks by ATR back in 1991. Next up for the car is subframe connectors, a Terry Houston 3" downpipe, and possibly an ATR 3" exhaust and a few assorted other tweaks... I'm so close to 11's I can taste it
I've got a couple questions about the factory PCV/breather system though. I've read that under boost, the PCV essentially backflows pressurized air into the crankcase and can pressurize the motor and pop seals, and not only that it forces all that nice contaminant-laden blowby back into the inlet bell of the turbo and over time will plug up the intercooler.
Am I way off base here? Is there anything else I can add/do, such as a checkvalve on the PCV, an open breather on the oil fill cap, etc? Or is the stock setup OK?
Another thing-- why the heck are there coolant lines running to the throttle body? All I can figure is that it's a cold weather deal GM added to possibly prevent freezing/sticking of the IAC and/or throttle butterfly. Is it safe to loop the two hoses from the coolant pipes and cap off the passage in the throttle body?
Thanks!
Thanks!
