cecil bass
- Aug 27, 2012
I just replaced the knock sensor now the engine won't start ..... I took a reading from across the coil pack I'm getting 10.6 Ohms, now I dont know what to do....... Some one help me track down this problem
Yes tried loosening the bolt all the wires are going to right cylinder......Does your plug wires match this technical drawing?
...and did you loosen off that 1/4 bolt that holds the wiring harness to the coil module?
