TurboPowered68
My DD is a 98 Regal GS and in the past I already experimented with how much E85 I could add without causing problems. I am running an Aeroforce Interceptor so I can monitor every aspect of my engine and I have the LEDs set to come on with 2degrees of knock. My car also runs a few mods to include intake, ZZP tune, front plog and rear ported manifold, ZZP downpipe with high flow cat and GTP resonator and dual exhaust. With this setup I got up to about 3 1/2 gallons before I started throwing lean codes, I think this came up during part throttle no boost situations because I recorded several boosted runs with around 3/4 throttle to full throttle and O2 was good with 0 knock. I can put 2 1/2 to 3 gallons in with a full tank but the only thing I can verify for sure was small loss in MPG. By the seat of my pants I MIGHT HAVE felt a little more but I didn't take it to the track that way so I cannot verify anything. On another note if my dad fills up his park avenue ultra (stock SC 3800) with Caseys gas, which is 87 with enough ethanol to get it to 91 he gets better MPG than with 91 pure gas. Again hard to compare the two as his stock engine hits 6psi where I'm maxing at 11psi.
