Scott89TTA
- Jul 12, 2005
I've been looking at universal K&N filters for my car and found this model RX-3990-1. It has the X-Stream top/end instead of the solid end. Since we are trying to get some cold air from the fender well this filter should do a better job then the 8" (RE-0910) & 9" (RE-0810) universal filters most have been using. I have read where some get the longer filter and smash it down a little to get it in the fender well opening. It looks as if this may not be necessary with the RX-3990-1 ? The only thing I'm not real sure about is how much CFM is required on modified TTA's and GN's?
Here are the CFM numbers I got from the K&N tech's...
1. RE-0910 8" Universal ~725 CFM
2. RE-0810 9" Universal ~901 CFM
3. RX-3990-1 8 11/16" X-Steam Universal ~850 CFM
http://www.knfilters.com/search/product.aspx?Prod=RX-3990-1
Cost is around $62
http://www.ajusa.com/cgi-bin/knfilt...0-1&ajr_skey=02cbedea141a523ce920cebd9589842e
Anybody use this filter...if so what are you opinions?
Thanks,
Cost is around $62
Thanks,
