I have verified with a thermal sensor, a scan tool and my autometer gauge. The stock gauge is off by quite a bit, it reads lower than actual. All three show with in 2 degrees. I have replaced all the sensors checked all of the wiring. I have the aftermarket fans hot wired for maximum efficiency. The water pump is from GM basically new, and I could believe one radiator being bad But I have tried 3 aluminum radiators from be-cool, CAS, and a custom that is for a big block swap into the third gen. All even the bigblock monster (which required "cutting" to get in) have had just about the same results.
