Got my new head gasket back on after getting the head resurfaced and put it all back together and now it has some knock that I cant get rid of.It ranges from 0.5 to 3.5 on a run from 1st through 3rd gear.All of the knock occurs at the end of 2nd and 1st half of 3rd.I thought maybe bad gas so I put in 10 gallons of 110 in and running alky alky so octane isnt an issue.It has the same knock at 19lbs of boost as it does at 24.I have added and subtracted fuel to 10.4 on the wideband and 11.0 and still the same results....cant get rid of the KR.Never had this issue prior to blowing the gasket.Plugs look fine.
I assume Maybe its a rod bearing or something of that nature,There was alot of gunk on the pick-up tube when I pulled the pan to clean it up...Maybe I hurt something more than the head gasket?
