ok guys i have been trying to figure out this knock noise on my engind but im at a lost. here is the story. a long time ago you caould hear a slight what sounded like a valve tap. it went on for that like months with no probs. the other day i put oin my turbo and stuff when iu started thje car i noticed the noise was knocking louder. now that noise makes no difference wether it is cold or hot its the same either way. it sounds like it comeing from the bottom of the engine and its def. on the passenger side. i have pulled off spark plug wires to see if the noise changes and no change. i have checked the oil and dipstick under fine light and no metal. i have great oil pressure. i took the valve cover off today on teh passenger side and there was nothing loose. the one thing i found weird was when i drive the car up on car ramps the nosie went away and was quiet until i went in the car and gave it a few revs hten it came back. sounds like maybe something hitting something. the nosie goes up with rpm.s but you cant really hear it as much over 2200 rpms. i looked around the belt system to see if anything was hitting but i did not see anyting. its not coming from teh cam sensor either i have been putting a pipe up to everyting to hear. if anything its coming from the bottom area on the passenger side by the oil filter. any ideas on what to try next without dropping the pan would be nince, thanks
