NorCalTurbos
Slowing down to SPEED UP!!!
- Nov 9, 2013
Soon as I get a chance will do, thanksDefinitely check that fuel pressure. Bad pump hurt my motor last year.
SignUp Now!Soon as I get a chance will do, thanksDefinitely check that fuel pressure. Bad pump hurt my motor last year.
Those are a starting point . Same as base timing. Different cars might like different settings. It is up to you to find out if that is the case for your car and what those new numbers are. Most call it tuning. Same as twisting the screwdriver on a carb and goofing with a timing light, just done with a laptop.Ive been wondering why do I have an adjustable fpr if its suppose to be set at 43 with the line off and 38 with the line on and that's it. thanks a bunch I think ill try adding fuel through the fpr.... I didn't even think of this, thanks.
Thanks I kinda figured that, I was just unsure, but you put it in simple terms for me thanks for the inputThose are a starting point . Same as base timing. Different cars might like different settings. It is up to you to find out if that is the case for your car and what those new numbers are. Most call it tuning. Same as twisting the screwdriver on a carb and goofing with a timing light, just done with a laptop.
Sent from my HTC PH39100 using Tapatalk
I haven't had a chance to do anything yet, my wife is 4 months pregnant and becoming very needy at the moment hopefully I get a chance this weekend to do some tinkering. How about you and the hvac lines? Did You get it figured out?Hows your car coming?
I thought I would get a chance to do some troubleshooting today but I haven't made it home yet, I'm at Walmart with my old lady right now, she wanted a new laptopI haven't had a chance to do anything yet, my wife is 4 months pregnant and becoming very needy at the moment hopefully I get a chance this weekend to do some tinkering. How about you and the hvac lines? Did You get it figured out?
Not yet, im debating hooking up a long vacuum line to it and tieing it out of the way, installing the turbo and then figure out the vacuum line later.I haven't had a chance to do anything yet, my wife is 4 months pregnant and becoming very needy at the moment hopefully I get a chance this weekend to do some tinkering. How about you and the hvac lines? Did You get it figured out?
Thanks, I'm gonna try that first I'm just getting home and I was gonna add fuel at the rail but I was also thinking like you said, Eric even said adjust the timingReal quick. I had similiar KR which forced me to go intercooled because it was just too much a PIA to see the KR and worry about it all the time. First get teh 02 up to low 800s. Next get your timing that is adjustable in your chip to 13*, I believe its set by using the block learn and intergrator to 98 versus 128. If it goes away...good. It should go away. You need to have alky if not already
Is base timing the #s on the chip? If so it says 19/17•I don't know if I missed it but was base timing verified?
No. Check stickies for directions on timing verificationIs base timing the #s on the chip? If so it says 19/17•
The timing was set 25 ATDC months ago I'm starting to think its the coil and module it runs great before it warms up very lil knock if any guy as soon as it's at running temp the idle goes all to hell at stop lights it begins to shake, kinda embarrassing then the knock starts and it shifts like it has a 2800 stall in it. But anyway i set the translator at 0 for ls1 and up the FP at the rail, it ran great until it warmed up??????No. Check stickies for directions on timing verification
