NorCalTurbos
Slowing down to SPEED UP!!!
- Nov 9, 2013
Oh yea..... Btw it is sorry for the late responseI'm still waiting for you to verify fuel pressure is rising 1 for 1 with boost.
SignUp Now!Oh yea..... Btw it is sorry for the late responseI'm still waiting for you to verify fuel pressure is rising 1 for 1 with boost.
What do you have for fuel pressure? Plugs new? Wires ohm good? Pressure rising with boost? New fuel filter? Coils on pack ohm good?I've been having similar problems for months. The car knocks under boost (anything upwards of 8 lbs). It is also a bit stumbley and rough. Where in nor cal are you?
I'm in American canyon it's a small town between Fairfield and Vallejo I'm driving the car today to take some notes as to how it runs. Are you in California also?I've been having similar problems for months. The car knocks under boost (anything upwards of 8 lbs). It is also a bit stumbley and rough. Where in nor cal are you?
Base timing was set 25• ATDC when I first got the car runningI don't know if I missed it but was base timing verified?
Fuel pressure is goodI'm still waiting for you to verify fuel pressure is rising 1 for 1 with boost.
It should be 15Base timing was set 25• ATDC when I first got the car running
I've read somewhere that it was 25, is that for the IC cars or what? I took the car out and it runs crappy when it warms up, bad idle, motor starts to shake and its temp is about 200• while runningIt should be 15
I'm not sure about 84-85I've read somewhere that it was 25, is that for the IC cars or what? I took the car out and it runs crappy when it warms up, bad idle, motor starts to shake and its temp is about 200• while running
Ok so here are some scan tool #s the O2 seems to be low at idle 103-148
Af 06
L8 35
Int 128
Bl 142
Clt 132
Rpm 1000
Tps .46
Iac 05
Cc 66-136
That's cold start pretty much
Once it's warm
O2 97-152
Af 06
Int 128
Bl 142
Clt 187
Rpm 1000
Tps .46
Iac 0
Cc steady at 140
These #s are at idle in park, The engine is shaking cold and warm idk what's going on I moved on to the suspension because of the frustration
Iac set it runs better not right thoughIAC at 0 could = a vac leak. It can also account for the hi idle.
H2O temp is higher than I'd expect w/ a 160 stat.
BL at 142 = adding fuel.
You were right brother vac leak pcv lineIAC at 0 could = a vac leak. It can also account for the hi idle.
