The car is knocking at full throttle with the boost down at like 16psi. The scan master said as much as 2.0degrees of knock retard. Where should i start from here. I need to tune the car desperatly.... Part throttle its great, no hesitation or pinging and she pulls hard. Little bit of smoke out the tailpipes when i get on it and it pings but part throttle and cruising no smoke. Also none at startup....
Any input appreciated,
David
David
