The longer shoes will help your TR hold more boost if you don't have a jumper-style system. Expect to be able to hold another pound, MAYBE two. No more. The most significant part of the gains you'll see in the rear brakes' ability to hold boost is in the actual replacement of the pads with a softer-compound set.
One point to take note of that I haven't seen much mention on these forums is that by using the longer shoes from two sets, the factory self-adjusters are placed at a non-stock angle, and may not adjust themselves properly. You'll need to check them periodically, depending on how much you drive the car.
