Late shifting into 4th
Bugsy
My 87 GN just had a new engine installed along with a 3200 stall converter , new high friction clutch packs and the governor tweaked to give higher shift points under full throttle . Before this the car shifted normally , now it shifts great 1-2 and 2-3 but revs to almost 4000 rpm before it shifts into 4th under light throttle . As a result it cruises at 50 mph at 3500 rpm which is too high
The TV cable is set right . Any suggestions to get it to shift into 4th at a lower rpm under light throttle ?
