Hi All,
Well, the PM on my WE4 started acting up (leaking) last fall, and I'm now getting around to trying to fix it since I have it back together and ready (almost) to bring out for the season.
Anyway, it started to leak around the gray switch base. So, I tried a new o-ring... still leaked. Bought a different (known good) gray switch... still leaks. So, I was down on fluid and added some after following the proper instructions. Leaked worse!
Should I try two o-rings around the base of the switch? I was told that when the switch goes bad, it is because they leak to the inside where the connector goes... so why does MINE have to be different?!
I should mention that I did swap the PM for vacuum brakes on my GN and love them, but I've tried so hard to keep my WE4 as stock appearing as possible, I can't see throwing on a big ol' vacuum system.
Thanks,
Thanks,
