I'll start by saying I think my problem is due to something I did (or did wrongly).
I have the LED kit Scot sells.
It's all connected now.
The passenger side is working perfectly.......no problems. Running lights, lights, brakes, signals, hazards all work great.
Driver's side is the problem.
1 - turn the running lights or headlights on......it works fine. No problem.
2 - turn on the signal.........nothing.
3 - turn on the hazards.........nothing.
4 - with the lights on.......signal or hazards don't do anything.
I'm feeling kinda sick to my stomach thinking I have to un-wire all the driver's side to check every connection !
I'm thinking it not the "power" line, since the lights work.
It can't be the ground either, for the same reason.
So it has to be either the "brown" wire, the "yellow" wire, or the "green" wire.
With the above symptoms, does anyone know which of the 3 I should be checking ??
Or anything else I may have screwed up.
I really appreciate any help.
Chris
Chris
