SignUp Now!hi, i was just wondering if it is possible to check preload without pulling the intake off and what tools you would need to do so? i was just wondering what mine is if you have .090".
IT would be hard, but you could get a pushrod checker (adjustable pushrod)and adjust it where you just have drag on it. that would be zero, get a pushrod ..040 longer.
Cool, i actually have a pushrod length checker from Crane and i just ordered a slide caliper so i could measure the checker.
\I don't think shims under the rocker shafts is a great way to adjust preload. Yes it will work, but it will also cause unwanted geometry problems between the tip of the rocker and the valve tip. This will side load the valve and cause guide wear.
I have to disagree with the statement that raising the pedistal with a shim method should never be used. The shim material must be quality material that is hard, and perfectly flat. With that said, putting a washer under it is not advisable. The correct geometry must be verified, which tends to limit the amount you can raise the pedistal to around .015-.020 in. My point is this. It can be used, if done correctly, with reliable results.
Thats exactly what you would do and its not very hard either. Just be sure your on the base circle of the cam when checking the length. Then just get a set of pushrods that are .030in longer +or-.010in.
