SignUp Now!Yeah, but you haven't even identified what the noise is. There's a chance you don't have to kill a running car to fix the noise.
Have you gone under the car to check the convertor bolts to see if they are loose? The only real gaskets for the exhaust you need are the headers and the three bolt turbo gasket. If you have a aftermarket down pipe that can go on with nothing or a little copper rtv. take sometime out and check out your exhaust pipes even aftermarket ones crack.
My advice is to not use gaskets between the manifold and head or turbo and manifold. The exhaust pressure will blow them out and it will have a real big exhaust leak after it happens
BPE2013@hotmail.com
Take them in and get the flanged surfaced and eliminate the gasket. That's how they came from GM.
Mobile larrym
For me I was alway pushing gaskets out. Checked my flanges with a straight edge and decided that they needed to be faced. I had planned to run a gasket after they were staightened up but decided I would try them without. Worked great on both my stockers and my old kennebell sets.
Mobile larrym
No offense to you in particular, but no matter where I read, everyone has their two cents on what to do with headers.Gasket, no gasket, felpro, rimflex, copper, rtv.. I can see why I shouldn't use a gasket on the turbo-to-downpipe flange. I can see that the majority consensus about stock manifolds is to not use gaskets because it worked the best from factory, but when I do searches about aftermarket headers, people can't agree on what to do. Maybe I just haven't looked hard enough but that's the way it seems.
Well then I put nothing on it? No thin layer of silicone? Just metal?
The pressure in the ex is still there no matter what header is used and for what it's worth a non f'd with set of stock headers is flatter than any other header I've ever seen. No gasket means no gasket to blow out. I've r&r headers hundreds of times. They seal best when no gasket is used and both surfaces are flat without pitting.No offense to you in particular, but no matter where I read, everyone has their two cents on what to do with headers.Gasket, no gasket, felpro, rimflex, copper, rtv.. I can see why I shouldn't use a gasket on the turbo-to-downpipe flange. I can see that the majority consensus about stock manifolds is to not use gaskets because it worked the best from factory, but when I do searches about aftermarket headers, people can't agree on what to do. Maybe I just haven't looked hard enough but that's the way it seems.
