light situation...?
turbobooster
at one point all my interior lghts worked the problem ive had is the gear console where it shows the gears and after market boost gage lights dont light up anymore when i turn parking and headlights on heres the crazy part wen driving in daylight headlights off the stock turbo and tach gage function as soon as i turn headlights on the stock gages dont lite up anymore ive checkd fuses all are good any ideas or tips? is there a specific wire or wires i should checkout?
i dont know to much about these regals i just got one not to long ago but it does sound like a ground wire
It's a wiring issue for sure. Whether it's a ground or a short I can't tell you though.
Have you tried to mess with your Dimmer control for the dash lights?
If you put your headlights on and the Dimmer switch is all the way turned down those lights will barely illuminate.
i would double check the wire job you did when you installed those gauages.
