Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
I would like to install line-loc so I can do a burnout without heating the rear pads. My questions are:
1) Are guys using an ashtray pod switch? If not where are you mounting the switch.
2) I assume the solenoid is threaded SAE. Do you just cut the line to the front brakes and reflare them with SAE compression (double flared) fittings or do you have to use metric fittings and then an adapter?
3) Do they affect the normal braking to the front calipers?
4) How long does the solenoid last? Are they reliable?
Thanks.
Thanks.
