Dave Levey
- May 24, 2001
I recently rebuilt my trans to the specs by CK in his manual including dual feeding direct, at extremely light acceleration the shifts are very very soft at 1/4 to 1/2 throttle they are tire barking crisp. At WOT they are back to soft. another unique thing is that with the convertor locked when shifting from two to three it unlocks before the shift occurs then locks again after the shift.
Pressure readings are
p 65 -225
r 100-150
od 65-175
d 65-160
2 160-160
1 150-150
Any ideas where to start, without better guidance I will start swapping parts, (PR springs, valve body and spacer) The last build on the trans had the red TCI spacer plate and a shorter pr spring and pressures in OD were 75 and 190 if that helps.
p 65 -225
r 100-150
od 65-175
d 65-160
2 160-160
1 150-150
