Little Maftpro Question
bradinwva
Hey everybody. I just bought my first GN and it has a Maftpro on it and I have a question. The car Starts and runs like a top but has a miss that kinda bugs me. The only time you have the miss is after yu pull out at a kinda slow take off and just as it starts to come into the boost it has a noticable miss. Once you bet into the boost the miss completely dissappears. any ideas on what I need to adjust to clear this up? here is a list of whats done t the car.
ATR rear sway bar
3" terry Huston down pipe w/cut out jet hot coated
ATR drivers side header coated same as above
3" ATR exaust duel
Brian Hoffer Hi/Po trans brand new /no lock up art car 3200 stall converter
motor ballanced an blueprinted by local motor shop wh dose most GN motors in Se michigan 20 over diamond pistons coated piston berrings combuston chambers, ARP bolts and Studs through out 10/10 stock crank and rods
206/206 Comp cam roller lifters
new batt
new F-body Rad
all sensors replaced with new AC delco parts
Wide band 02
Full throttle speed maf less system dialed in completly
Ta performance cover/cluches new
new Kenwood reciver 6 new speakers
Alky Controls Progressive kit Pac controller
Metco lower cntrol arms
Egt
30 psi Boost Gage
oil psi Gage
Trans temp gage
like new interior
RJC pulleys
62mm throttle body ported intake to match.
brad
