BISON,
I do realize the 9.5" is the way to go for a track setup. You and Dusty have been very informative in previous conversations. Unfortunately that converter requires some serious dough which I need to keep in my pocket for now.
WSLN 6,
A taller tire is a good idea. I'm currently running 275/50 Nitto 555R's which are just shy of 26". Until last weekend they have performed well for me, but now I'm spinning the crap out of them at the track. If I run into the same problem this weekend I was considering taking a look at Hoosier's 27" DOT slick or whatever other vendor is at the track.
DUSTY,
Yes the converter is still stalling between 2900-3000 rpm at 0-1 psi. From the logs it also looks like 3400-3500 at 5 psi. Attached is my best run from the 1/8th mile if you'd like to take a closer look. I'm just concerned about running out of rpm toward the finish and from what I understand will be giving some up if I have to shift to OD. I'm comfortable running the motor to 6100 rpm but have no idea how much further it can be pushed. Everything is built but it still has the stock crank and rods.
Also, could someone explain in more detail why this converter can not handle a WOT lock? I believe what you guys are saying, just would like to know some of the technical reasons. There seems to be a lot of people that do lock their converters. Are they being foolish?
