- Nov 30, 2009
What is needed to log fuel pressure on my powerlogger ? I have a transducer for my Autometer FP gauge , do I need another one or can you parallel off of the single transducer ??
SignUp Now!Ran my autometer gauge / powerlogger off the same transducer. I just tapped into the signal wire (solder) and ran ran to my PL. I believe the signal wire was purple IIRC
Just make sure whatever tranducer you use has an output that changes voltage.
If it changes impedance (ohms), it won't work.
