I was helping a friend with his Speed Pro and I went to setup the data logging trigger. He wanted it to trigger using the TPS. The setting was defaulted at 50% and I tried to move the bar on the scale to about 90% and it seemed to be locked at that value. The bar would move but the value stayed at 50%. I tried adjust the TPS both on and off line with the same result. I also tried the RPM's trigger and that value could not be changed either.Any ideas.
Thanks,
Jeff
Thanks,
Jeff
