cutluse231
- Jun 10, 2001
?`s about 200r4 VS 400
As you guys can tell by my signature I currently have a 200R4 behind my 455 in my 82 Regal.
What Im experincing is what seems to be excessive and long time to shift out of 1st gear.
When It does shift it either hits hard or you have to feather the gas to get it to change gears.
The Trans is from my 86 GN , The carb is the factory 800cfm Q-jet that came with my "71" 455, the Tv/throttle cable bracket is from a 1986 Oldsmobile with a 307 and a 200r4 trans.
The trans has been rebuilt about 2 years ago, a 10 vane pump, heavy duty stator & the clutches where "blue Plates", and heavier duty something for the 1st and second gears,(cant remember) stock valvebody , no shift kit, and the converter is a D5 rebuilt to "Red Stripe " specs ( that is what they (trans shop) told Me)
Also is it probable That my Tourq converter is the issue?
The bracketry that connects the tv cable to the carb is crude but works.
The TCC lock up does work ,ran pwr from ign source to terminal "A" on the plug and ran it through the brake switch wich also has the switch already built in to cut cruise when brakes are applied that cruise switch is what Im using , the pwr is always there cause the solenoid is self grounding and wont activate the lockup till it sees fourth gear, shuts off when brakes are applied.
NOW THE FUN STUFF>>> Questions!!!
I beleive I got the TV cable adjustment just about right (*note I think, I do not have access to trans PSI gauge)
Would this have an effect on the long delayed shift, flat peformance feel before 1st gear change?
If its deeper and trans needs rebulit I have a 400TH long tail shaft that came with the eng. How hard would it be to convert it to a short tail shaft trans and beef it up, also would it be hard to convert it (400TH) to have lower 1st gear set?
Just concerned on what to do I know that 455 combo with 3.42 gears should really move off the line , but my car sounds like 4:11`s on 13 "rims lotsa RPMs in 1st gear ( sounds good actually) but my Ford Areostar will take it from the line .
Got any Ideas......I would love to have the OD in the 200R4 but I dont want to sink that much more money into the car.
Thanks for the band width and sorry so long winded
