Looking for convertor opinions
Lee Thompson
455 Olds in a Olds G body---500 HP--500 Ft Lbs. torque. 3.73 rear with a 28 in. tire. Putting a built BQ trans in. Leaning toward N/L but need opinions on which convertor and what stall. No highway driving--No drag strip --just Sat. nite cruising. Thanks
12" 1800 stall. Assuming it pulls at least 12" or more of vacuum just off idle.
Couple of options!
If your looking for an inexpensive option, a stock d5 should net you around 2400 rpm and can be lock-up or converted to non-lock.
Then you have many versions of the 9.5'' (stock cover converted, billet cover, etc) wich could be l/u or n/l.
If the cam has a lot of duration at .050, it's no fun having a lock-up when the cam is stumbling at real low speeds.
I like th D5 idea as well for an enexpensive route, but also think a PTC l/u 10" converter would do well as well. The are affordable and in a lower hp application (ie not a 10 second monster) it should work pretty well. We are going to run a tight 2800 PTC 10" l/u in our 540 ci chevelle (675/674 flywheel hp/trq). The coupling should be as good or better than a 12", but with less weight and probably more torque multiplication.
It shouldn't be taking much cam to get that torque from a 455. Being that it's a cruiser, I would also go with the D5. A little more performance than a stocker 1800.
Where you plan on shifting it at?
I have done several 10" converters for BB cars and they work well. 2400 or 2800 are options.
I run a slightly upgraded D5 with in my 455 GSX. Turned a 12.42 with it. Probably not 500Hp more like 450. Right on the edge of what it can handle but did not cost a lot. For cruising and street use it was fine. This year I am working on Procharging it so will need to upgrade.
