Looking for info on bigger engine build. 4.1---270ish inch Discuss
fastblackracing
Hey guys, I am ready to start getting stuff for my next engine, 012 block and am looking for opinons on what overseas crank and rods that are working good recently. The pistons will be custom my specs from wiseco and I will be using a 3.625 crank and 6.00 to 6.350 rod. Are 6.200 rods available? The block is a little short on deck height and 6.500 rod wont work with a decent ring package and compresion height. I have some carillo stuff left over but I really think I need a shorter rod. So Id like to hear whats the trend now and working out the best. This will be standard head pretty much max effort deal. Discuss​
Cunningham can make you any rod that you want. The popular off the shelf hi-po rod at the moment is the Crower 6.300 from TA. Is your crank wide or narrow journaled?
Call Mike at Full Throttle. He knows what you need. He can supply everything you need. I just built a few engines with his stuff. One runs 9.92@136+ on pump gas and alky.
