DougsfastZ
4.1
- Jan 30, 2004
The best short I've had is a 1.65, looking to get into the 1.5x's if at all possible with the stock turbo/intercooler/converter. I do drive the car about 500 miles a year.
This is what I have now.
- Removed front sway bar, ATR rear sway bar
- QA1 single adjustables up front (set to 3)
- Monroe Sensatrac shocks in the rear
- Adjustable upper control arms (pinion angle set to -3)
- Metco lowers with relocation brackets
- Stock springs all around
- MT ET Street Radials 275/60/15's, usually at 13 psi cold
- No preload set
I am looking to put QA1 single adjustables in the rear along with a H&R rear sway bar. What would be some good springs I can put front and rear for better weight transfer? I read the Moroso trick springs are garbage. Anything I can do with the front control arms? Front shock snubbers? Rear pinion snubber?
Really looking to maximize weight transfer when I leave the line. The car leaves nice and straight right now. The pic in the sig was a 1.69 short.
Thanks for any help,
Doug D
- No preload set
Doug D
