231ci champion extreme ported irons t&d 1.6 roller rockers girdled steel crank k-1 rods je pistons ta headers 3"thdp champion ported intake 70mm throttle valve 160lb injectors for e-85 fast xfi precision fmic th400 rmvb with trans brake PTC 9.5 tc 3.42 axle ratio 28" tall tire I shift a 6000 looking for a good street strip turbo I currently have a pt6162e journal bearing I believe this will be holding me back from a mid to low 10sec pass on a full weight gn
I'm leery of the precision dbb turbos because from what I read the cannot be easily rebuilt unlike the turbonetics turbo
cam card
Grind # BV69 3108S /3109S HR112.0
DURATION @ .050 INTAKE 215 ROCKER ARM
RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 220 INTAKE 1.50
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3340 EXHAUST 1.50
VALVE LIFT INTAKE .501 LOBE LIFT EXHAUST .3420
VALVE LIFT EXHAUST .513 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 110.0
TAPPET LIFT INTAKE 271 CAM ADVANCE 2
TAPPET LIFT EXHAUST 276 HYDRAULIC Y
cam card
RATIO
