williambavila
William Avila (The Buick Guy)
- May 11, 2010
Mike i did the engine myself local machine shop did the machine work i made sure that it was clean maybe i missed something. did a 30min. run changed the oil and filter and again at about 200 miles after that i only drove the car on weekends, now be steel crank/rods/dimond or go stroker, dont realy now what the issue is but back to the drawing board all ideas or direction will be greatly appreciated thanks.
Just have the block cleaned out good from the machine shop ask them to clean it before and after installing all freeze plugs and galley plugs. Then do it again with hot soapy water at a car wash at home then blow it out you also need to spray some kind of graphite spray on the cylinder walls so they dont rust in the assembly process.. Keep it clean I can assure you thats what happened to the other block.
