Toddmc66
Import punisher.
- Dec 26, 2012
Recently purchase a 87 T-Type excellent shape. After cleaning up the engine area I took it for a test drive, only getting 10lbs of boost. Engine falls on its face around 4900 to 5000 rpms and you can see the front end lower as the engine stops pulling. Feels as if the timing is backing off or ignition is stumbling. These are the checks and repairs made but problem still exist. No exhaust leaks, no vacuum leaks, set the TPS, check the (Y) or (T) that goes to the boost sensor, turbo and waste gate actuator. Found the (T) has an orfice in it, swapped the two hoses that go to the turbo and actuator, now have 15lbs of boost. Car still continues to fall on its face around 5000 rpms unless I only give it 7/8 throttle and then it pulls hard and continues to pull hard. tried disconnecting the boost sensor (same thing) added a Razor Alcohal Kit (same thing) engine pulls harder with the Razor kit but still has this problem. Sometimes if I keep the pedal to the floor it pulls hard then falls on its face until it shifts into 2nd then pulls hard again untill it reaches the upper rpms. I've also tried adjusting the trans cable, (no change.) Fuel pressure is at 42lbs. These are the upgrade's. 205/210 cam, Red Armstrong double pumper fuel pump, rebuilt factory turbo, Red Armstrong 93 chip, rebuilt factory heads, Razor Alcohol kit using methinol, 55lb injectors, 200R4 rebuilt performace trans with 2800 stall, 3" down pipe 3" exhaust with Dynomax mufflers, Factory rear, E3 spark plugs. Hopefully with all this info someone out there has run into this problem. Sorry to be so long winded.
