18 inches and steady , cant ask for any better then that
when i was pulling my clips, the two i pulled there was no change in idle so i knew i had a couple of bad ones
when was last time you cleaned your IAC? throttle body? and maybe it needs a little less air, although its right in line as far as numbers go, in my buhog bible it says it can be anywhere from 10 to 30 somthing in park and all cars are diff.
i always see the magic number from 10 to 20 but one guy i talked to says his is set at 35 in park and i had a bitch of a time (as everyone prolly has) getting it set to where it liked to be which is 23 for my car and i was quick to notice when i bought new one that the pintle was over the inch and 8th adjustment so i had to adjust so it wouldnt jam up in seat.
So we know its a lean issue at idle, when you unplug air sensor id goes to enrich, when its in gear it idles fine and numbers go up...hmmm man got me run a couple gallons of toulene, maybe an injector or two got crud on em
i dont know, i hurt my knee at work and its midnight and i cant sleep and my brain is frying
