Low Brake Pedal Help.
Rugby
I have an 87 gn and the break pedal is low. The car was converted to vacuum breaks before I bought it.
The rear breaks have s10 wheel cylinders with factory regal shoes. There is slight drag on the drums.
I changed the front pads and rotors today because I had a wrapped rotor. I put EBC green stuff pads on it.
I have bleed the system several times.
Where else should I look?
So, the pedal wasn't low before you did the pad swap? Pedal has been low since you bought it? Not sure you have the correct pedal/mounting place on the pedal. Generally a vac swap requires a vac pedal to work correctly. Or the mounting point needs to be moved to get the correct geometry for the vac system.
Sent from my HTC PH39100 using Tapatalk
The pedal has alway been low. I need to do more digging into the car.
