May 4, 2018 #1 M Matt a New Member Joined May 4, 2018 Messages 5 At low idle the car stumbles and chatters on the bottom end. Sounds fine when you rev it and it builds boost fine. Any ideas?
May 4, 2018 #2 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 1,977 check for vacuum leaks all hose leading to the vacuum block.
May 4, 2018 #4 J jay dcpt Active Member Joined Feb 8, 2010 Messages 438 Like a engine noise or just running rough?
May 4, 2018 #5 M Matt a New Member Joined May 4, 2018 Messages 5 jay dcpt said: Like a engine noise or just running rough? Click to expand... Engine noise
May 4, 2018 #6 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,539 I'll say loose intercooler bolts and/or loose torque converter bolts.
May 5, 2018 #7 dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Messages 4,039 I would check Converter bolts , balancer bolt (220ft-lbs), and your intercooller bracket hardware.
May 5, 2018 #8 Pronto No amount of evidence will ever persuade an idiot. Joined Dec 9, 2002 Messages 16,746 When did it start happening?
May 5, 2018 #9 M Matt a New Member Joined May 4, 2018 Messages 5 About 99% sure it is piston slap. It goes away for the most part after it warms up.
May 5, 2018 #10 M Matt a New Member Joined May 4, 2018 Messages 5 Debating on doing a 5.3 swap with a turbo.
May 5, 2018 #11 J jay dcpt Active Member Joined Feb 8, 2010 Messages 438 Where you located? Let me know if you want to sell the engine. And trans if you want.
May 5, 2018 #12 J jay dcpt Active Member Joined Feb 8, 2010 Messages 438 And I'm just saying that if you head that direction and your sure its internal and not a quick fix. Ls swaps are awesome but if it were me I would fix it. I'm just one of those people that think a gn isn't a gn without a turbo 6.
