BEATAV8
The Engine Whisperer
- Feb 14, 2002
well i would start checking how the oil looks and cut open the filter it won't hurt to check the bearings just because the motor has been rebuilt don't mean anything.
X2 cut open your old filter and look for debris in the pleats of the element and also look in the bottom of the filter can for sparklies or worse... some sparklies are normal for a brand spanking new engine but after a few oil changes you should not see much.
You can cut the filter open with a utility knife and a good pair of heavy gloves or mechanics gloves to protect your hands in case you slip. it's OK to let it drain first you won't loose any of the trapped nasties inside.
