well i got a new stroker done last year and really havent drove it has some problems. first motor is in my sig and has a blueprinted timing cover and oil pump. my oil pressure is 55 cold and hot is 10psi at 165 degrees when 185 it is 5 to 8psi. this is with 20/50. what should i do? i am not running an oil cooler. would that make a difference? and should i get a bigggie oil adapter? weber says it is ok because i am getting volume from the ported cover. another thing is i get alot of knock in first gear 10.8 a/f though on scanner. it has to be false i went over the car with a fine tooth comb and cant find anything banging. i do get alot of tire spin even easing into it at 45mph. if i rev it in park it will register knock.
