Apr 19, 2004 #1 5 5ltretr Member Joined Jul 1, 2003 Messages 873 I took off my lower control arm , the back bushing is smaller than the front , anyone have a part number for the bigger bushing? thanks
Apr 19, 2004 #2 5 5ltretr Member Joined Jul 1, 2003 Messages 873 These are the front lower control arm bushings
Apr 20, 2004 #3 Turbo6inKY Short Guy TurboBuick.Com Supporter! Joined Jun 18, 2001 Messages 2,281 Perfect Circle (Dana) bushings from AutoZone: Upper (both): FB398 Front Lower: FB399 Rear Lower: FB400 Moog sells them in kits Upper K6411 Lower K6177 You need one kit per control arm (two of each to do the car). They should be able to cross reference those back a to a GM part number if you want to get OEM bushings.
