SignUp Now!Nick, I was talking to you at Kirban's show about doing a 500 chp V6, but the LSA looks like a better swap. ................. Does the LSA clear to stock hvac box and whose install kit did you use? Thanks.
Mark
I'm not planning on turbos at all, just the lsa. I need to rebuild the trans and get a converter anyways, so another trans is still in the budget. If the engine clears the hvac box, then i can go with a different compressor and hoses. Found these guys, but haven't heard back yet if the lsa fits with stock hvac box http://www.brphotrods.com/products/82-88 G body products/index.htmlI have 2 comments for you.
I would NOT attempt to do this project with the stock AC unit, as it would never work with 2 turbos added.
Second, a 600 CHP turbo Buick would be MUCH cheaper than a LSA and a 4L80-E!
The Vintage Air kit is one we developed a couple years ago for G-Body vehicles.
Here is the link:
http://www.turbobuick.com/forums/th...-air-under-dash-unit-has-it-been-done.391683/
Nick, I was talking to you at Kirban's show about doing a 500 chp V6, but the LSA looks like a better swap. I plan on using crate LSA and a 4l80e trans. Hopefully also using GMPP's LSA controller and trans controller. Does the LSA clear to stock hvac box and whose install kit did you use? Thanks.
Mark
