LS turbo project..
Chuck Leeper
Toxic old bastard
Staff member
86T blackout car.
347" iron LS based engine, 4L80E, Quick 9".
Some details:
Short block by Jentzen Racing, NY.
ALL Fresh, never run combo.
Dominator system. Wiring 90% completed.
PTC. {Lockup for street use}.
Forged pistons, rods.
Livernois ported 317 heads.
Bullet Cams hyd roller.
Truck exh manifolds, 304 ss piping.
Exh system completed.
BW S400SX3 turbo. 75/81, 87/81 Ext tip, T4, by Work Turbo.
PTE gate.
Edelbrock intake, Fast 4bbl t/b.
Racetronix dbl 680, fuel system completed.
New fuel tank.
Wolfe Racing ARB.
Poly body mts.
Rear cont arm mts reinforced.
Frame reinforced, boxed.
Viking dbl adjustable shocks all 4 corners.
Spohn tubular rear control arms.
Weld pro Stars, BFG tires. {All new}.
Hydraboost.
Autometer dash.
Razors alky.
UPDATE:
New, OEM weather strip kit.
Viar on board air system for boost control.
UMI tubular ft upper a-arms.
NICE upper door panels.
B psi, alky psi, dome psi sensors added and wired to Dominator.
Fender inners, core support blasted, painted.
"Trick 3rd gear jump" system for launch boost build.
Alky kit wired for delay when launch boosting.
Needs some minor body work, paint.
Ft seats need re-covered. {Gray leather pillows}.
Sure there's more..............
$15,000
Not with it all clean and "pretty"...:D
.Have many of the hot side build, frame, etc, that have been posted before.
Some...
More...
Chuck, where are you from? Ga? I'd like to check it out if so. I live out in west Georgia.
Bump.....
Blu car is gone. Starting back on this project. Have some of the listed parts to install.
Someone needs a winter project!!:D
Bump....
More pics to upload.
New price, w/ many more items added.
All wiring completed, engine started, base tuned
Air intake fabbed, plumbed, Turbosmart BOV added
AIT @ turbo outlet added
Spoolfool fillers, ft and rear
New park/ turn, corner lite assys
New headlite bezels
NOTE: The OEM door seals are not installed, as the new owner may choose to repaint. Same for other items marked "NIB"
ACC carpet NIB
Interior Fatmatted, with rear bulkhead sealed off
Inner/outer dew sweeps NIB
New door handles, & seals NIB
New ABS Headliner
New visors NIB
Windshield trim seals NIB
Bumpers stripped and painted
Alum bumper reinforcements
Alky pump mount fabbed and completed.
Turbo intake elbo & filter added
Custom console panel w/ LED lit switches for 3rd gear "jump" for boost build, Alky control for boost build, air compressor control, etc. Boost build controls are selectable, and run thru the line lock sw
All wiring w/ nylon mesh wrap. NO plastic hard covers
USB connection for Dominator wired to dash
Tailites restored
Remaining assembly work will be completed prior to delivery
I can deliver within 500 mi, for expenses. No delivery prior to completion of sale
Can assist w/ pick up by transporter
$18,500.00, or best REASONABLE offer.
NO TRADES
