BTW the KYB's come with this screwed up double ended shock mount. Using that the shocks hit the banjo bolt for the brake lines. I canned those and used the old shocks mount bolt. The KYB piece you can see in the pic on the top of this page with the white monte carlo. It holds the shock out half and inch. The old mount bolt brings it closer to the rear end housing. Which allows for better clearance without relocating the shock.
You should have tried turning the KYB bolt around.
